Advice on camber setting for track
Hey folks, I just did my alignment today along with diff fluid change and brake flush with motul rbf 600. Here are the numbers I went with.
I'm also ordering new pads from G-loc . R12 front R10 rear. When I look into the manual for the installation it says that I have to discard the rear bolts and pad clips. Does anyone know the part number for these? Is that necessary to do it (like why isn't necessary for the front?). You have to get new bolts every time you switch pads ? Thanks
View attachment 111697View attachment 111696
ran into same issue when i installed the same Gloc Pads. I did not buy new rear pad clips/shims or bolts, and instead just reused the OEM stuff after cleaning them up a bit with brakecleaner. I put some brake grease between the pad shims and backing plates for the rears and reassembled without any issue. there were no shims on the front so thats why no similar mention for the front brakes. Reused the bolts on the front too
Hot pressure targets of 30 psi front and 28 psi rear. Start them at 23/21 and bleed down to targets when they're hot.
Don't make it a bigger deal than it is.
I have been running high cambers and lower pressures with good results, both in performance and tire wear.
How did you arrive at -2psi on the rear axle? Weight distribution? Lap time?
