- Thread starter
- #41
Looks like the rear stepped out.
Turn in looks complete within 0:06 markers
Steady state for all of 0:07
At the start of 0:08, you can see a blip in the G-meter/bubble. Looks like theres a patch in the paving or something that you roll over there. Rear probably let go there.
Without seeing your hands, I think it could have been recovered if you were quick to counter-steer. But might also help if you soften the rear damping or stiffen the front assuming the setup is a bit loose for your paving. The front looks like it stuck through the turn.
I will stiffen the front sway bar and lower the rear LCA a little more (top hole in BMR setup, was in middle hole). They should be just a degree or so down after the adjustment. Rear shocks are full soft with 18mm bar and fronts are full stiff.
