Jim my tire wear stock was not as bad as yours, but I ran 45 to 46 psi hot on my 2012 Boss stock so that reduced the outside edge wear somewhat. With -2 of camber and 41 psi hot on my 2013 Boss the outside edge wear is improved, but not eliminated. The boss really needs more camber IMO, but I'm not ready to spend the money on camber plates.YellowJacketBoss302 said:Thanks again for all the replys. OK -- I'll go to the cords.
Any estimate as to when that might be? As in how many more track days?
HackBoss302 - were your wear patterns like mine? How did they change with - 2 degrees camber?
Thanks.
- Jim
Hi Ron. Can I flip the tires even though they have asymmetric tread?blacksheep-1 said:Invest in one of these, they are expensive but will pay dividends in the long run............
http://www.longacreracing.com/catalog/item.asp?id=188&catid=7
Your tires are fine but try "flipping them" for more life.
