F.D. Sako said:Steve!
I asked you to sign my shifter bracket... remember?! 8)
Ultrakla$$ic said:My question is will I have to remove anything off of my MGW to put this Blowfish shifter fix on my car.....ie...will I have parts from my MGW that will be replaced by the shifter bracket that comes with this product???
thehueypilot said:Great install video. What are you doing about the shifter mounting studs hanging down from the floor pan? Can these studs hit your new bracket when the transmission flexes under heavy load? It was hard to see what was going on up there in the video.
Tim
Ultrakla$$ic said:So with the new shifter bracket, there's gonna be a ton of Barton pieces in the FORSALE section.
F.D. Sako said:Looking at the vid and pics, the only thing you would have to remove/modify is the heat shield.
Is the rear mount solid? If so, I may have to put in the less flexible insert for the MGW rear mount.
Calif boss302 said:
Ultrakla$$ic said:Thanks guys. I see it all now!!! I'm pumped!! That's about as solid as you can get right there!! 8)
Calif boss302 said:We are all excited . . .mine is on order and can't wait. Now I'm deciding since I have a brand new MGW Shifter sitting in a box do I do both at the same time, or just the blowfish then the MGW? Hate to install the bracket only to take it off to install the shifter later. Either way a fix is on the way!
WinterSucks said:I would install both, unless money is an issue. The MGW feels a lot better.
thehueypilot said:It would be interesting to know what the Ford Design Team thinks of this fix. Anyone got any contacts within the Engineering department?
Tim
pufferfish said:i just upped the initial order to 300 units to cover the cjpp order and hopefully get enough inventory to not go on immediate backorder. so, i should be sending out pre-orders right after labor day, as well as stocking up cjpp and fullfilling as many retail orders as i can at the same time.
so far, every order submitted to date will be fulfilled in this batch.
pufferfish said:Pretty sure that pic was of a bench demo, which of course needed the rods to not make the shifter flop to the floor.
Grant 302 said:Can we still get the $229 price before 9/1?
