Grant 302 said:No real problem, except that it's not the *whole* seal. If there's anything left in the bore, you should get it out. It the seal is all burned out and gone, don't worry about it. I wouldn't bother replacing the seal unless or until you run titanium shims.
Are you running cooling ducts? Those should also help if you aren't already.
NFSBOSS said:I've noticed my seals are shot too. I just installed new pads and added the Ti shims. I never drive my car in the rain so should I bother replacing the seals?
This.Grant 302 said:I don't worry about water, but am more concerned about dust getting to the piston seals and mucking up the bores.
Fat Boss said:Thanks for the info, guys. And Logan, every time I see your name this goes through my head.
