Centerforce DYAD update
Justin
Figured I would come back to give you guys an update on the clutch. It has yet to stick to the floor or do any other of the odd things that was happening with the stock clutch. The only complaint I have is the noise it makes when you push in the clutch. other than that I love it. lighter pedal than stock. super smooth shifts.
Thanks for the update and welcome back.
Found him on a milk carton last week, dragged him back to BMO... :D
Can you give some more detail on this "noise". It's when you push the clutch pedal in? Is it a clunk, clank, swish, creak, clack?
And secondly, is this a known side effect or is there a remedy for it?
When I installed an Exedy clutch, I had to put in a completely different T.O. If I used the original T.O. I was told both noises and possibly liquid (brake fluid) failure could occur!
its a rattle I was told by centerforce its the couter weights on the pressure plate and is nothing to worry about and if I wanted I could remove the weights but it would bring its holding power down. when I get back in port in a few weeks I will take a video of the noise. its kinda loud with the windows down.
