If you can sleep in a golf cart…I’d say you’re damn tired.
It is notIsn’t the Mach 1 HP essentially the same car as a GT350? Maybe some slight differences?
I think the two biggest are mechanically the flat-plane crank "Voodoo" engine in the GT350 vs. a "normal" cross-plane crank Coyote in the Mach 1, and visually the wider front fenders with rear vents on the GT350 to allow for a slightly wider front track. The Mach 1 does share the Tremec gearbox with the GT350, plus some other "trickle down" parts.Maybe some slight differences?
Rightfully so! That was blatant…we want this manufacturer to do well and not this one.I do imagine with all the Ford Big Wigs there for the event John Doonan ( IMSA President. ) will be getting more than an earful!!!!
