How far would you run these tires for track use?
These are the original front tires from my 2017 GT350. They are down to the wear bars and the shoulders are worn down. I am having them replaced tomorrow but for future reference I'd like to know if they can safely be run longer on track or is now the right time?
If you're trailering they'll be fine in the dry. How many heat cycles do you have on them? I know high treadwear street tires aren't supposed to heat cycle out but if you've got 30 heat cycles or six track days on them I suspect their grip is less than desired.
8,507
8,549
VoodooBoss has a solid added note, as I have a tendency to assume folks are trailering their car as I do, when in reality there are tons of guys that do not - and I drove to the track for many, many years.
The tires had at least 50 heat cycles in them over at least a dozen track days. Last time out it was almost 100 degrees and pretty sketchy. Now I'm thinking I should have replaced the rears too.
I don't trailer the car unless I go out of state and I'm fortunate to live only 15 minutes from the track so I just drive the car.
