In this good Economy my millenial A/C has quit its job...14 GT
Discussion in 'Boss 302 and S197 Technical Forum' started by gripdriver, Sep 17, 2018.
  1. gripdriver
    gripdriver TMO Race
    249
    127
    Jun 27, 2017
    Arizona
    2014 GT TP with 44k miles
    A/C started blowing hot air. No bad fuses, no bad relay's. I did put a gauge on the Low side port to see if it was low on R134A...it was not.
    I spun the compressor clutch by hand, it does not spin very freely, and my hand was covered in a fine black grease or oil?
    With the A/c off and the engine running the clutch sits still and the pulley rotates with the belt. When I turn the A/C on Max A/C and Max fan, the clutch still does not move, but the car kicks up the idle like it engaged the A/C, and the low speed cooling fan comes on.
    Does this sound like I need a new A/C compressor?
    I have never had a car with A/C issues, so I am going off what little info I could find on this subject that is relevant to the 11-14 S197 mustangs.
    Thank you.
    Grant 302 likes this.
  2. GTerDUN
    GTerDUN TMO Intermediate
    17
    11
    Jun 14, 2017
    Cary, NC
    Exact same thing happened to me last year at 41,000 miles on my 2011 GT. The compressor was toast and you could see what looked like melted plastic on it. I ended up replacing the compressor along with the accumulator, expansion valve, and hoses while I was in there. If you're going to replace the parts with OEM Ford parts I've got P/Ns for you:
    Accumulator: AR3Z-19C836-A
    Expansion valve: DR3Z-19849-A
    Compressor Assembly: BR3Z-19703-B
    AC Hoses: CR3Z-19972-B
  3. gripdriver
    gripdriver TMO Race
    249
    127
    Jun 27, 2017
    Arizona
    thanks for the part numbers!
    My whole system is in good shape, so I may just replace the compressor as well as the switch for good measure. If I can fix the A/C for under $400, and get another 40k miles out of it id be happy. The next time the A/C dies in this car I am stripping the entire A/C system out of the car. That will be the start of it becoming less of a daily driver, and more of a "track car".
    Anyone else have any input or ideas?
  4. Grant 302
    Grant 302 OPM Spent: $665,833 Moderator
    6,797
    1,722
    Nov 23, 2011
    In the OC
    Sounds like it.
    ...and I like the revised title better! lol. :D
    gripdriver likes this.
  5. Swiss Boss
    Swiss Boss TMO Addict
    519
    167
    Jan 13, 2013
    Racing Capital of the world
    I've a compressor for sale if you're interested
  6. Racerpilotalan
    Racerpilotalan TMO Advanced
    165
    40
    Jul 23, 2013
    Houston Texas The Center of The Universe
    My car has under 16k miles and the A/C quit the first of Summer. I didn't many chances to take it out since it isn't my DD.
    Friday I take it to the shop and the A/C still blows hot. After lunch I call them and it's working. I think the vales in the compressor got stuck from sitting up.
    It's back to blowing cold.
  7. Bill Pemberton
    Bill Pemberton TMO Addict
    2,799
    1,515
    Sep 30, 2011
    Well Racerpilot has it all figured out..........like many millennials it just works when it wants too,hehe!
    gripdriver and Racerpilotalan like this.
  8. gripdriver
    gripdriver TMO Race
    249
    127
    Jun 27, 2017
    Arizona
    Where are you located? Is it new?
  9. byronj
    byronj TMO Addict
    1,523
    429
    Jul 17, 2012
    Bay Area
    One went out at around 40K. The very front part of the compressor shears off. If you didn’t know what you were looking at you couldn’t tell. Everything was still in place and it acted as if it worked normal. Only blew hot air though. I had that fine black grease on mine as well. Had to replace the compressor unit and everything was fine.
  10. Swiss Boss
    519
    167
    Jan 13, 2013
    Indianapolis. Stock unit of my 2012 Boss. I had about 15000mi when I removed it. Been sitting for 2-3 years on a shelf at work
  11. thehueypilot
    thehueypilot TMO Advanced
    182
    54
    Feb 10, 2014
    Medina, TN
    Maybe just a bad compressor clutch.
    Tim
  12. gripdriver
    gripdriver TMO Race
    249
    127
    Jun 27, 2017
    Arizona
    Z
    Thank you for the offer, I am going to order a new one for $338 and hopefully it gets me through 2 more AZ summers.
  13. gripdriver
    gripdriver TMO Race
    249
    127
    Jun 27, 2017
    Arizona
    This give
    This is what ill end up doing. Just put in a new compressor and be done for a little while with the A/C drama.
  14. gripdriver
    gripdriver TMO Race
    249
    127
    Jun 27, 2017
    Arizona
    Cut the A/C belt when i got home today. No need to have the engine keep spinning the useless compressor.
    New compressor is ordered, and i have the ford A/C idler pulley/tensioner and belt setup already.
  15. byronj
    byronj TMO Addict
    1,523
    429
    Jul 17, 2012
    Bay Area
    Good luck. You’ll need an extra hand.
Share This Page
