Let's Talk Aero
Big Black
Good, fast<del>, and cheap</del>
I would like to reduce "lift" generated from high speed operation. Which application, tiger racing hood or an LS style splitter, would be more effective? I am sure there are many variables at play, just trying to keep it simple in a complicated environment.
There are no simple answers here, but it might be 'easiest' to reduce lift by dealing with your hood, probably cheaper...anybody smarter than me chip in
Big Black
Grant's posts 107, 113 and 117 are a really good read. Basically, a lowered, properly raked (flat bottom - lol) chassis with a suitably sized splitter can increase downforce by lowering undercar pressure...lots of "voodoo" in this area...(waiting for a quip from @VoodooBoss).
My money would go first, however, to reducing overcar lift by blocking/ducting the rad and ventilating the hood effectively. This can significantly re-profile the bulk of the airflow and thereby, reduce how much the thing flies the nose. Lots of (cost effective) ways to block/duct the rad...construction foam, sheet metal...but no cheap solution for a ventilated hood. Tiger and Kohr offer race-proven (worth the money) options.
@RES_22 good take.
Great question...I'd rather answer *after* I do more testing!
But in the interest of testing what I think I know...I'll give a shot at it.
I think the LS splitter would net more than any vented hood. At 100 mph I'd expect the top of the splitter to have points that are greater than +2.5" w.c. on the top surface and possibly average more than that over the entire surface when considering the low pressure underside, which can be large and somewhat adjustable with ride height.
The only point I've taken so far on the hood is at the rear side at the bulb seal and measured about -1" w.c. (lift). While this wasn't really near any of the points in question for a vented hood or specifically the Tiger Racing one, I don't think there's enough area to vent a hood to match the potential from the splitter.
That's my best guess for now, comparing them as single theoretical modifications.
@Grant 302 Those pictures are great. That is an excellent shot of the splitter function, maybe the best I've seen.
Thanks, Chris. Gotta credit Ford for sharing that video publicly a while back. They took it down shortly after. I should know, but not certain...I think it's part of the video in the Boss owner's kit.
At the end of the day, it's just kinda hard to extract big gains from a splitter without having access to empirical data for sweet ride height/rake ranges and splitter sizing for your application.
That's a big reason why I want to eventually test my mostly stock Boss too. Better understanding should come with more data collecting. At least I hope so!
This is absolutely true. Especially when both of these mods would somewhat work together. The vented hood would help 'protect' the underbody low pressure. And/or the splitter slightly reduces underhood pressures and lift in that area.
I made one pass in the left hand sweeper. This is what I mean about how the flow changes in a turn.
Splitter flow on outside of turn:
I should have backed up for that shot. Just to the right, the droplets were still in place below:
So I'm sure that G forces aren't pushing the droplets around. I dusted this area with some corn starch to show up on video. That was a bust since there was traffic (sub 60mph) where I was trying to make a run on the freeway for the straight line flow. I should probably video using wool tufts next time for both.
Since I have a Boss, I'm not going to cut the hood. I would have to buy another hood and then add vents to it, which puts me close to the price of a fiberglass tiger hood. I am going to work on building a splitter, like what Swiss Boss did, then potentially complement it with a vented hood if I can find a deal on a GT hood locally. Grant, I like the idea of the vortex generators on the rear and was wondering if you had tried them on the sides of the car/rear window, and what the result were.
I've only tried them on the back window so far. Most of the pictures I have are a few pages back in this thread. I haven't quantified any results, but have observed more attached flow on the upper spoiler and wing surfaces. I have tried other arrangements further down the back window with other staggered layouts, but I'm pretty sure I lost all of those in a computer crash.
6,556
8,208
And for my next trick.....I will now attempt to transfer the information in this book into my tiny brain without a net...somebody que the clowns......f53b644ca25eb729f25182f8cd0ea943.jpg
Fair
Go Big or Go Home
277
492
Plano, TX
Somebody mentioned the TrackSpec louvers, which are becoming popular lately.
One of our customers used these on his C6 Corvette (above) before buying a vented hood (below)
We have done a good bit of aero work on some S197s lately, including updates to Jamie's ST3 Mustang...
He had a very successful rookie year in NASA and took the regional ST3 championship. Car is getting faster and setting class track records, easy to drive, wearing tires perfectly.
After an unfortunate incident with a "gator" at NOLA the front end is undergoing some updates in our shop right now
I am going to revive our old S197 build thread soon to show the many changes made to this car over the past 2 years + several other aero tricks and updates to some other S197s.
I've been racing a gutless BMW for 2 years but finally made it fast with some aero updates before the last race. Damn I miss that Coyote V8...
All absorbed now, right? You should have taken before/after hat size measurements. :p ;)
Managed a wool tuft test on the splitter yesterday afternoon.
Side view so you can see that some of the tufts are raised:
Frame 1:
Frame 2:
Video scrolling roughly between the two frames, goes forward, backward then forward:
I am accelerating from a stop between Frame 1 and 2 in a 50 mph zone.
There are 8 tufts in the test:
1- near the center directly on the splitter and does nothing for all the video taken.
2- on the splitter near the front just inboard of the stanchion/rod
3- on the stanchion/rod
4- raised ~3/4"
5- raised ~1.5"
6- on the splitter
7- raised ~1"
8- on the splitter most outboard in this test
I'll post later on my interpretation of what's going on later and follow up with a similar post for the on-ramp to freeway run.
1,250
1,244
In the V6L
...The only point I've taken so far on the hood is at the rear side at the bulb seal and measured about -1" w.c. (lift). While this wasn't really near any of the points in question for a vented hood or specifically the Tiger Racing one, I don't think there's enough area to vent a hood to match the potential from the splitter...
I think you'll get a big effect on lift if you can counter that 1" WC of vacuum somehow. Let's just say that the hood and fender area is about 4' square or so, then 1" WC gives you about 85 pounds of lift. That's a lot.
6,556
8,208
I think my first step will be remembering to bring the book home. Didn’t do me much good last night on my desk at work.
I agree that's a big target and why most want to reduce it. The main issue is how much surface can you remove and vent before it causes other problems. And we're somewhat limited to only remove after the radiator and before the rear bulb seal, and to leave some in for structural purposes. The good news is that venting up front should reduce that 1" for the area immediately downstream too.
LOL. Now you gotta sleep at work!
6,556
8,208
Been there plenty...I have a big facility here with spare offices...I gave some serious thought to just putting in a shower and moving in.
6,556
8,208
Reduced commuting expense could justify a workplace upgrade that might include more shuteye as a bonus...;)
I used to live literally 90 seconds from here, so the commute wasn't a big thing.
Now I live 15 minutes away, time for the turbos to warm up.
I have a couch and some other stuff in my back office so I have slept here more than once, but it's all about having a shower. I came very close to having my contractor friend make an apartment in here but in the end I decided not to....I had the plans drawn up and everything but if somebody complained I would have to move out of it and tear it all down so the risk just wasn't worth the reward. Now I just use the extra office space to store my race day stuff. $1.50/sq. ft. to store folding chairs and EZ ups lol. Pretty expensive storage space if you look at it like that but I don't need 4 offices and they won't let me tear them out so......
6,556
8,208
Fabman, sounds like you have all the bases covered , except maybe for that shower....perhaps Tymeslayer could help you with that small detail?....:D
I wanted to add a Shower, laundry room and full kitchen. I have a microwave, fridge and sink already plus that end of the building has its own big ass bathroom, plus its all air conditioned which is nice. But none of this is about aero so we should not thread jack this any more...
Big Black
Terry, Looking forward to your contribution to this thread. "Tricks and updates...YESSSS!
