OK, I am sure many know this little trick to swap pads on the fronts but I thought I would throw it up for anyone still pulling the calipers for a pad swap. This is also a good way to swap pads even if you will change rotors and pull the caliper anyway since you avoid putting pressure on the lines and do not have to deal with a swinging loose caliper.
Doing this correctly should take less then 5 minutes per side.
Remove the pins that hold the pads and tension clip in place.
Then remove the clip. (YES, I know the clip is on backwards I threw it back on to take the picture)
I simply grab the rotor and pull outward, this will push the pads and in turn the pistons back into the calipers.
This will give you enough space to pull the pads right out.
As part of my track kit I carry a burnt out pad to slide in and then use a screwdriver to push the piston all the way back in. No worries about damage to the old pad. You will need to do this if installing new pads since pulling the rotor out will not compress the pistons all the way.
I have done quick pads swaps many times at the track this way. Since it is so quick I do not throw out a set of pads that may have a run or two left on them because I want to do it at the house before hand. I now carry a set of bedded in pads to all events just in case.
