drano38
Wayne
- 1,130
- 318
Putting new Centric rotors and Carbotech XP-8 pads on the rear of the Boss tonite, but can't get the piston turned back in far enough.
I'm using a kit like this to turn it:
http://www.amazon.com/Precision-Brake-Caliper-Wind-Back/dp/B00GAC768Q/ref=sr_1_4?s=automotive&ie=UTF8&qid=1432091485&sr=1-4&keywords=disc+brake+piston+tool
New rotor and pads measures 2.07". Max I can get the piston pushed back in is ~ 1.9"
I've tried rocking the piston back and forth, but not gaining anything.
I installed SS brake lines tonite also, so the caliper is empty of fluid--that shouldn't matter should it? I opened the bleeder too, and no luck.
It seems the piston just doesn't want to go in any further, and I'm putting pretty good pressure on the tool trying to turn it.
Just need to put more pressure on the tool? Or is there some trick I'm not aware of?
Thanks in advance for the help.
