Sandwich plate torque
jneary
Performance Fords
323
Norcal
OK, I bought a sandwich plate to add an oil pressure sensor and gauge pod. What should I torque the adapter nipple to that fastens the plate to the oil filter stud? Thanks in advance...
John
jneary
Performance Fords
323
Norcal
OK, perfect. That is quite the stack up you have there. Did you remotely mount the sensor or did you mount the sensor to the plate directly? They recommend remotely mounting the sensor on engines where vibration could pose a problem and with that many stacked up, that could multiply the forces...
Thanks again for the feedback!
John
1,936
2,036
Michigan
John
I mounted the sensors directly to the first sandwich plate.
The stack isn't as big as you may have thought as I've removed the Stock Oil/Water cooler. A combined sensor/cooler sandwich plate wouldn't package with the cooler removed, which is why I ended up with 2 plates....
