Steeda Shifter Base Bushing
I have that along with the Steeda shifter. I think it helps alot as far as taking slop out of the factory shifter. Once you see the factory bushing, you will see a big difference between the two.
The stock rear shifter bushing/bracket is total crap, and is the main source of shifter balkiness in our cars. The Steeda bushing/bracket, which looks pretty similar to the Barton bushing/bracket I have in my Boss, should work great... my Barton bushing/bracket completely eliminated the shifter hanging up between gears on high RPM shifts. Shifts just fine now. Highly recommended mod.
I will be installing this piece within the week. Like stated in the 2 previous replies, it has to be better than the flimsy stock bushing/bracket. It may not work miracles, but the stock piece must go.
TMO Vendor Posts
