Strut bolt
As per my usual I always forget one last minute detail. Does anyone know the specs on the front strut bolt? I need two to replace the camber bolts.
Cancelled my order and grabbed some 5/8's bolts, they are larger than the M14 stock strut bolts so I will figure out how to make them work but I feel better about them than the Ford bolts, plus I didn't have to wait to have them sent and what not.
4,019
1,966
Brandon
Why are you not using the Ford bolts? I advise against making the hole in the spindle upright larger by any means. There were failures on early S197 uprights due to bolt torque loss and material thickness. The uprights/spindles were beefed up in 2010 and the bolts changed from coarse thread to fine, with an increase in torque value to 166 lb/ft.
Race teams still use OEM bolts and flag nuts there, wouldn't risk a failure by modding it.
steveespo said:
Brandon
I didn't want to use the Ford bolts since a set online was 32 shipped and a local dealer could only sell sets of 4 nuts and bolts and that was roughly 70 dollars. Seems like I am quibbling over a few dollars when safety is at stake. I will have to see when I go to putting it all together, I may have to run by Ace or something and see if they have M14 bolts that are Grade 8 or higher.
4,019
1,966
Maximum Motorsports sells them as a complete kit for about $46 a set of 4.
These are the Ford bolts. http://www.maximummotorsports.com/Strut-to-spindle-mounting-hardware-kit-2005-2014-Mustang-P1360.aspx
Steve is absolutely right about those bolts. I have replaced mine with the Ford bolts both times I replaced the struts. These are catastrophic if they fail and I know of a few that did before they swapped to the fine thread bolts. I am swapping to the FRPP rear LCAs with poly bushings next week and just stopped at Ford today to pick up new hardware. I thought $40 was steep for that too but not in comparison to a potential failure.
I just ordered the correct stuff from fastenal, prior to finding out that Maximum sells the bolts for cheaper. How do the coarse thread fail over fine thread?
Noticed the difference between the old and new threads. I changed my order to fine thread and will see where that gets me, went with 10.9 just like Ford's bolts.
Ford designed these bolts to replace the coarse-thread OEM bolts that originally came on the 2005-10 Mustang. The stock bolts have been known to loosen over time with aggressive driving road racing or autocross allowing strut deflection and breakage. These redesigned bolts have a fine thread and higher torque spec (166 ft. lb.) that helps them to better withstand the abuses of hard cornering.
1,936
2,036
Michigan
Agree 100% on only using Ford hardware. Swapped out stock suspension for coilovers this winter and found that Group1autoparts.com had the best prices.
$38 for a set of front strut nuts and bolts: http://www.group1autoparts.com/parts-catalog/ford/mustang/2012/boss-302/5-0l-v8-gas/front-suspension/struts-and-components
