Thanks Mark. Does that mean there's not much benefit to changing it to a lighter one-piece or did the 302S just get the two piece for cost reasons?mwilson7 said:302R uses a unique 1 piece driveshaft that is not interchangeable with any other trans in the FRPP line up. The Boss 302S comes with the same 2 piece driveshaft as a 2012 Shelby.
cloud9 said:Thanks Mark. Does that mean there's not much benefit to changing it to a lighter one-piece or did the 302S just get the two piece for cost reasons?mwilson7 said:The Boss 302S comes with the same 2 piece driveshaft as a 2012 Shelby.
cloud9 said:Which one does Dean use and which one did you install? Why do you feel you need a safety loop? Did you put a blower on that car Scott?
This one? This is like the one I had in my GT500. I wonder if the new FRPP lowering springs would require an adj UCA to correct pinion angle.ArizonaGT said:Dynotech
cloud9 said:I wonder if the new FRPP lowering springs would require an adj UCA to correct pinion angle.
Now we just need the springs. I've got my install all set...2012YellowBoss said:cloud9 said:I wonder if the new FRPP lowering springs would require an adj UCA to correct pinion angle.
From what I was told no. There will not be a need to change anything.
drano38 said:Scott,
What camber plates are you running, and what do you have them set at?
I've got MM at -2.4 and scuffed off the outer shoulders pretty good on 3 track days. May not have enough tire pressure.
When I get dedicated track tires, hopefully I can get it dialed in better like you are.
