- Thread starter
- #21
NFSBOSS said:John, how are the Enkei wheels holding up with all the flat tires?
LS110 said:Guys - I actually survived an event without a blown tire last Monday.
LS110 said:Scott & Rob - It sounds like both of you are determining tire pressure based on wear and temps. How are you bringing grip into the equation? I have clearly been going with too low of pressures trying to maximize grip.
If you have even temperatures across the tire face, the grip will come, don't take that to the extreme however, the inside will always have a slightly higher temp due to camber, so it should increase as it goes across the face of the tire, if the two inside temperatures are close, it would suggest a high pressure, and thus, the opposite would also be true. More left turns would also show an increase..etc..etc..etc. But ALWAYS relate temps with pressures..and log it.Scott & Rob - It sounds like both of you are determining tire pressure based on wear and temps. How are you bringing grip into the equation? I have clearly been going with too low of pressures trying to maximize grip.
I also use a non-contact laser reader and see the real racers use the contact type. I know it's better just not sure it is worth it for track day stuff. Same with nitrogen, I have gotten pretty good at adjusting with humid air so not worth the hassle.
Good info as always Rob. I do the same thing checking pressures the day before, in the shop out of the sun and then next morning at the track before sunrise after I unload. Most tires keep the correct pressure but a few of them lose a pound or two. I have only had one lose several pounds over night and did not run it.
blacksheep-1 said:If you have even pressures across the tire face, the grip will come, don't take that to the extreme however, the inside will always have a slightly higher temp due to camber, so it should increase as it goes across the face of the tire, if the two inside pressures are close, it would suggest a high pressure, and thus, the opposite would also be true. More left turns would also show an increase..etc..etc..etc. But ALWAYS relate temps with pressures..and log it.
LS110 said:Rob - I re-read your comment above and having trouble understanding it. Did you mean to say "temps" in a couple of spots instead of "pressure"?
blacksheep-1 said:Yes , the word should have been "temps" I fixed and highlighted it in the original post, sorry about that, hopefully that clears it up for you.
That makes sense now, thanks. So when you say even temps, and not to extreme, is even getting that within 10 degrees across the tire face, or less than that? I did order the temp probe device you recommended. Now all I need is a pit crew to measure it when I come in hot.
