Feel free to ask in PM
Alex
Alex
I grew up driving Fuller 5 speeds on Mack CF600 series fire trucks, around 1980 everything went Allison because kids couldn't drive sticks, we have the same problem today, kids drive a Honda all week, then want to wheel a 76K ladder truck through traffic.. lol your results may vary.There is only one true automatic transmission for the big trucks, Allison. They are a fairly expensive upgrade over the manual transmissions. About 20 grand upgrade for the big one capable of handling 550hp and 1550 ft lbs of torque. There are several automated manual transmissions and they are really catching on. Biggest problem is finding and keeping drivers. Then see if you can find one that can drive a manual trans. Very few of us left. As far as number of gears, five forward gears is the minimum, the most was probably the 20 speed Spicer, heavy haulers and off road users.
@flyhalf posted recently on Instagram that he just received his aftermarket aluminum pan for the 10R80. I’m sure he’ll have more to report soon with his review, but wanted to throw this out there as a few others are interested in this upgrade as well. @bob, I believe these guys are located here in SoCal.
https://www.ppepower.com/shop/heavy-duty-cast-aluminum-transmission-pan-ford-10r80-trans.html
An aftermarket TQ with a beefier multi clutch plate set up may be the solution.I had a feeling the lockup convertor was going to be a problem it has been that way since the old 700R4 GM trannies, I think I even mentioned it
I did. They are not a good option. They just mod OEM ones to stall at higher RPM.I’d talk to these guys:Ford HP Series 10R80 Torque Converter
HP Series Billet Stator Torque Converter Converter Diameter - 245mm or 258mmwww.circledspecialties.com
Of course that’s what they do. That’s where the money is at. But what (specifically) did you ask them about?I did. They are not a good option. They just mod OEM ones to stall at higher RPM.
When i called them they weren't interested to do somenthing for roadcourse.
Suncoast are next level. But man 3 grand is a lot.
Problem is. No one has experience for roadcourse. All focusing on drag racing
You don’t run with the traction control off?
I ran with track mode so the TC is 15% on.
BUT THE HARSH shifting create TC to kick in. In straight line full acceleration.
So a smoother 5-6 should fix it.
Somehow I'm just not much surprised . . .I would take the info that Flyhalf has accumulated and work with it, so far, it is the most comprehensive list I've seen, trying to get an automatic to work. It seems like this trans is great for magazine editors and road tests where the car is not beat on for an hour or more.. so it looks good on paper. Racing.. not so much
