Do you have data logs of the tranny activity when it’s hot?
The F150 converter sounds like its worth investigating. An even ‘tighter’ rebuild might help.
A manual bypass switch for the lockup sounds good too.
What are you using to tune the tranny? And do you have control over line pressures and lockup schedules and such?
It sounds that you are only a few tweaks away from being able to run 10/10ths at reasonable ambient temps.
