2013 Boss 302R brakes point to upgrade path
And from Mark Wilson here are the part numbers:
Below are the Brembo part numbers for the Brembo 380mm front brake package:
XB10511 LH front caliper
XB10512 RH front caliper
09852874 380mm LH disk
09852878 380mm RH disk
20B77115 Bracket (2 required)
16B77021 Bell (2 required)
X203026 Bobbin (20 required)
A10834105 screw (20 required)
O5579320 washer (20 required)
805019 stud (4 required)
MS7 nut (4 required)
WS7 washer (4 required)
These parts are not available from Ford Racing but should be available from any brembo dealer.
I made a little correction to the rotors below.
09.8528.74 OD 380mm, Thickness 32mm, 10 X 258mm, 72 Vanes, Left Rotor
09.8528.84 OD 380mm, Thickness 32mm, 10 X 258mm, 72 Vanes, Right Rotor
09.8528.78 OD 380mm, Thickness 35mm, 10 X 258mm, 72 Vanes, Left Rotor Type III
09.8528.88 OD 380mm, Thickness 35mm, 10 X 258mm, 72 Vanes, Right Rotor Type III
hprworld.com and cvproducts.com are original dealers of Brembo parts. I think Rehagen sells this setup as a kit and
porterfield-brakes.com should also carry them.
bbrgt - what pads are planning to run?
I have a nice set of the 380x32MM rotors listed above if anyone is interested.
Got all the parts from HRP world and I am running PFC 01's , they have 26 and 28 mm thick versions. I dealt with Michael Eddy and he had to get the parts from several locations , rotors were in N Carolina and the rest of the pieces came from California and their store in Edwards IL
Wow, are the 26 and 28's for the 380 only or do they have them for the 355MM? That would be sweet.
Do you guys run the titanium backing plates in the 302S? Was using them on the factory calipers and figured I would use them on the race Brembo calipers unless it is not recommended.
I am not running the titanium backing plates on the 302S , I think it's a good idea on any caliper.
As far as pads I am not sure if they have the thicker pads for the 355 rotor , and the pads for the 380 mm rotor are a different shape
Figured as much but unsure how they would react to these calipers. Guess I can punch a number in a search engineon the pads with the 26 or 28 instead of 25 to see if they are even made. I have been running the 08's and really like them but with the thickness of the pads with these caliper I might as go back to the 01's.
Have you ever run the 07's? I saw them being used on a 302R but looked like they almost melted since the center crack filled over. There are not many people using PFC's here but at least one person is using the 06's, they sound interesting for track day stuff.
No that's the old front 355mm rotor.
By the way the part number for the 380mm caliper is coming up as the mounting bracket only.
George
401
99WCrookie, thanks for the reply.
for the part number, I too had the same results on Google. Seems like they only call it that part number in the description of the bracket that's made for it. I spoke to porterfield today and they quoted me with this info,
Caliper, P4-38/42, 190x42, 2-piece, LHT
Caliper, P4-38/42, 190x42, 2-piece, RHT,
1900 each.
Sarosh
