This is how to from Alldata....
Removal and Installation
All vehicles
With the vehicle in NEUTRAL, position it on a hoist.
Recover the refrigerant.
Remove the 8 upper radiator air deflector pin-type retainers and remove the air deflector.
3.7L and 5.0L (4V) vehicles
Remove the Air Cleaner (ACL) housing and ACL (Air Cleaner) inlet pipe.
5.4L (4V) vehicles
Remove the 2 degas bottle bolts and position the degas bottle aside.
All vehicles
Remove the 4 upper radiator bracket bolts and the 2 upper radiator brackets.
To install, tighten to 10 Nm (89 lb-in).
Remove the condenser inlet fitting nut and disconnect the fitting.
Discard the O-ring seal and gasket seal.
To install, tighten to 15 Nm (133 lb-in).
NOTE: The radiator must be positioned rearward to access the 2 upper condenser bolts. Remove the 2 upper condenser bolts.
To install, tighten to 9 Nm (80 lb-in).
Remove the 9 lower radiator air deflector screws and the lower radiator air deflector.
Remove the condenser outlet fitting nut and disconnect the fitting.
Remove the 2 lower condenser nuts.
NOTE: The condenser core must be removed from below the vehicle. Remove the condenser core.
To install, reverse the removal procedure.
Install new gasket seals and O-ring seals.
Add the correct amount of clean PAG oil to the refrigerant system.
Evacuate, leak test and charge the refrigerant system.
All vehicles
5.4L (4V) vehicles
All vehicles
