captdistraction
GrumpyRacer
I'm tracking down a braking issue on my car that's sidelining my racing program.
The setup:
2011 GT racecar:
S197master cylinder, 13-14GT500 vacuum booster
new vacuum line to CJ manifold
new vacuum valve
stock lines from master to ABS and chassis hardlines, stock ABS valvebody
Race Abs controller
blowfish master cylinder brace (which was rubbing one of the lines, but didn't appear to crimp it)
S550 PP brake calipers, 13-14GT500 rotors, centering spacers
Gloc R18 pads up front, 13-14 GT500 brakes out back with DTC60 pads
Stainless lines
This setup previously worked fine with the stock GT booster, but had a softish pedal that didn't have much bite until low, but would claw one's face off when asked. This last weekend I ran a faster track, but had 2 issues:
1) variable boost from the booster, sometimes it was there, sometimes it wasn't, sometimes it worked for the first 1.5" of travel, then would be exhausted or repeated pressings would work for first press but then second press felt mostly manual
2) there was no bite at the top of the pedal, had to leg press the hell out of the system to generate braking torque.
This led to a very serious off during practice that nearly put the car in a wall at a alarming speed, and during the race I couldn't push more than 7/10's, and nearly punted a few cars as I had to check what sort of brakes I had going into each corner.
I've checked the system, had my ducts blocked off to ensure enough heat for pad bite was there, the calipers did reach 370* (not sure on rotor temps but looked nominal) and if I stood on it hard enough I could get the car to slow way down. However it took a leg press that was impossible to drive competitively with. My hamstring is still sore on the right side.
I've bled $200 worth of fluid through the system, and at this point completely lost. I believe it to be a hydraulic or vacuum issue, perhaps the wrong booster since the old booster worked better (we had tried restricting it, but that made matters worse as the pedal was a rock after what little boost there was). I'm thinking somewhere there's a restriction but not sure what. I've pulled everything apart and checked it, hooked up every diagnostic I can. Everything "looks" great.
before I start blanket replacing parts, any thoughts?
I have been looking at the Kohr master kit/booster and hardline to abs, thought about replacing the abs valvebody but it seemed to work fine when we put a IDS on it to do a bleed procedure, no errors in the system outside what is expected with the abs race box, all wheel sensors ok, etc. I don't think ABS is taking away braking. Also thought about putting a S550 brake booster and master on (and fabricating the hard lines) since those are a match for the front calipers (and the rears are similar)
here's a picture showing the car getting on its nose (note my head up as I'm sure I'm thinking about what questions to ask as I meet my maker):
The setup:
2011 GT racecar:
new vacuum valve
Race Abs controller
Stainless lines
