Thought I would respond and provide some clarification and gauge the interest in having brackets made
1) Material - If I make them they would be made out of steel, not aluminum, and not SS. More than likely it would be 12ga, i will see how the look and feel, might even go down to 14ga. If wanted I can powder coat them in either black, red, or leave them raw
2) Design - The design that I was planning on making was the original design that I believe someone posted a drawing for. I have the dimensions and specs from Ricky. Which looks similar to this, which I believe is a no drill bracket/attachment
Re: Different Oil Separator Installations
I created my own design, which I was not planning on making. Mine did require drilling 2 holes. It is a little more heavy duty, and again is made from sheet metal
I have had zero issues with this, and really no chance of it breaking. If there is interest in this one I can make it as well.
So what I am needing to know for those interested in the brackets, and reading what I posted about the material and design(s). Is the interest still there, and what design, or type of bracket do you want?
