What do you think of me using the Hawk HP plus pads for the track? Remember I am a beginner and don't want to start with the DTC 60 and eat up rotors. They are a bit cheaper then the ST41's.
Scott,
I checked with our Brembo rep and he advised me that unfortunately we do not carry or have access to the original equipment parts for the Brembo kit on your Boss. Typically a Ford dealership would be the only means of getting these parts.
Best regards,
Good point on the pads as I don't have a trailer. Like you I'm learning and this is all new to me. I'm also trying to learn from your experiences. ;D Hopefully I'll start learning first hand soon. My first track day will be similar to yours, the car will be stock with the expection of DOT 4 and brake ducts. From there I'll add wheels/tires then brake pads and finally rotors. The tires are a big one as I don't want to burn up the Pirelli's. OTOH they are one of the better street tires for the track. The challenge is finding a good street tire for the track at a reasonable price.2012Boss said:Others can comment here but from what I read Rick if you use the DTC 60's on the drive to the track you will be running red lights as they will not heat enough for street use. I would also not be real comfortable with NT05's type tire or better on the street, they say street-able but with rain etc. it could be a challenge.
Were you driving your M3 to and from the track with the HT10's?BossJockey said:Scott, The HP+ is a good starter pad. There easy on rotors and can handle some heat. The last time I tracked my M3, I use HT10s. They eat into your rotor some but its not like you'll have to replace your rotors every couple of track days. I have 10 track days on my rotors and they are maybe 1/4 to 1/3 worn out.
5 DOT 0 said:Good point on the pads as I don't have a trailer. Like you I'm learning and this is all new to me. I'm also trying to learn from your experiences. ;D Hopefully I'll start learning first hand soon. My first track day will be similar to yours, the car will be stock with the expection of DOT 4 and brake ducts. From there I'll add wheels/tires then brake pads and finally rotors. The tires are a big one as I don't want to burn up the Pirelli's. OTOH they are one of the better street tires for the track. The challenge is finding a good street tire for the track at a reasonable price.
2012Boss said:One of the guys at tire rack checked into the factory brake setup for me and sent an email
Scott,
Best regards,
Dean#4AI said:So they are saying they don't have OE rotors but they still have rotors that will fit, correct?
5 DOT 0 said:Were you driving your M3 to and from the track with the HT10's?BossJockey said:Scott, The HP+ is a good starter pad. There easy on rotors and can handle some heat. The last time I tracked my M3, I use HT10s. They eat into your rotor some but its not like you'll have to replace your rotors every couple of track days. I have 10 track days on my rotors and they are maybe 1/4 to 1/3 worn out.
Great info thanks for sharing. Which HP pads did you use? Others have stated the HP+ are good starter pads but the HPS are not.Boss_302 said:I used the stock GT500 rotors Ford Part Number 7R3Z-1125-A I could get these from my dealer for about $110 each. These replacement rotors are made by Brembo in Italy. Three to four weekends………….then new ones were needed, don’t worry about little heat stress risers on the surface of the rotors. As long as they don’t go across the top of the rotor from side to side.
For the rear I used the stock rotors made in Brazil, six to eight weekends……..
I started with Hawk HP Pads but didn’t like the fact those pads didn’t like the track heat and would overheat then I would get pad fade.
