Hi Guy's, I am just about to order camber plates, any opinion or review on one or the other...Thanks
ArizonaBOSS said:I've used both and both are great.
J&M obviously has a price advantage.
MM allows you to adjust caster, but I never even touched that in all the time I used them. The S197 has plenty of caster built into the geometry already.
Grant 302 said:Gotta correct you on that...the *new* J&M will do both caster and camber. It is also reversible so that it has a much greater range of camber adjustment.
Both brands advertise 0.7 degrees of caster range.
new '11-'14 J&M plates here:
http://www.americanmuscle.com/jm-caster-camber-plates-1114.html
ArizonaBOSS said:I was not aware, thanks! Looks like their design has become very similar to the MM plates (I'll leave it at that).
