FRPP is now offering the revised crank timing ring that was designed for the 2013 Cobra Jet cars.
http://fordracingparts.com/parts/part_details.asp?PartKeyField=22870
Shaun@AED said:
Hmmm...OLOABoss said:Maybe the definitive cure for the recurrent P0300
Peter
Shaun@AED said:If you get a P0300 take it to the dealer for a Neutral Profile Relearn.
Some shops have an IDS and can do the procedure as well.
I can as well.
Hermes said:I guess if someone wanted an 8100 RPM they would need to pick up one of these target wheels as well as new valve springs (load requirements on the valve spring increase by a surprising 20% when speed increases from 7500 to 8100) and I guess the new exhaust cam from the Cobra Jet. Then you would still need to reprogram the PCM to move fuel cut off from 7500 up to 8100 RPM. Maybe a tuner or FRPP might release the Cobra Jet tune.
