I was looking at the Vorshlag website and ran across this new bushing for the MT82 transmission in our Mustangs. Seems Vorshlag also has found out that aftermarket shifters do not solve the shifting lockout issue many of us have been experiencing. They think this bushing stiffens up the trans mount enough to remove enough movement to keep the trans and shifter in alignment while under load on a track. For approximately $35 this looks like a no-brainer. Does anyone know if you can get to this mount without removing the transmission? I'm not quite sure I've ever seen it before. Here's the article, link and photos.
http://www.vorshlag.com/forums/showthread.php?p=57592#post57592
"Whiteline Updates + New Trans Bushing Insert
We finally had time to add the Whiteline transmission bushing insert to the stock Mustang trans mount. The factory rubber trans mount bushing has massive voids that don't help the stiffness of this bushing one bit (see the picture, below left). Air is a terrible bushing material. Why does this matter? Well the Getrag MT-82 has a remote body mounted shifter, and the drivetrain is mounted on its own bushings. So when the transmission is loaded up (either with lateral g forces or under torque load) it moves relative to the body, and the shifter doesn't always then line up properly when you are trying to shift loaded up. This has been plaguing us for a while, and the "just add an aftermarket shifter" option doesn't fix the fact that the transmission is moving relative to the remote mounted shifter. At the NASA @ MSR-Houston event in January both Amy and I figured out quickly that we needed to shift earlier or later than we wanted to avoid shifting while in a high speed corner - because we would miss the shift every time. BONK! Frustrating.
Whiteline sent us the first prototype for this brand new KDT928 part, which is similar to other bushing "void inserts" they make for other cars. They were waiting for our feedback before they went to production - we gave them a big "yes, please!". This is an elastomer bushing insert that just pops into place and fills the air gap in the factory rubber bushing. We don't have official pricing yet but I was told the price "should be about the same as similar inserts we make", (so about $35). I have an open order for more, because this thing just flat-out works. Super easy to install (no tools, no effort!) and it firms up the transmission mounting nicely. Now installing this will add a little extra NVH (noise-vibration-harshness), just in case you are wondering.
Amy picked up the Mustang after we installed the insert and immediately came back after leaving the parking lot and said "Hey, something is different here...?" It isn't bad at all, just a little more NVH, and nothing like going to a full poly trans mount bushing would be. It just removes some of the air gap and firms the mount up a good bit. We should have these in stock before too long and I will post up in this thread when they are ready."
