ArizonaGT said:TBH just buy the Centric Blanks...they are "Cheap" by comparison and last just as long if not longer than these other rotors.
This is what I just did. Can't beat a full set of rotors for less than $250.
roadhouse said:This is what I just did. Can't beat a full set of rotors for less than $250.
KNS Brakes said:$250 sounds about right for the Centric blanks, I actually have them for $225 + shipping
-Nick
roadhouse said:I actually purchased them from you but couldn't remember how much they were. Thanks for getting me hooked up
KNS Brakes said:Is this Logan? I just got a notification from UPS that they got to your house a hour or so ago. Let me know how you like them! Hopefully those Stoptech SS Lines work well for you also.
-Nick
Scott is going to work on getting the 2013 GT500 caliper parts numbers. I would think with the proper mounting brackets front and rear you could run our calipers on the larger rotors which should help keep the brakes cooler. Hopefully the 15" rotors with calipers will fit inside 18" Enkei wheels. I wonder how much additional brake pad surface area there is on the six piston calipers vs. the four piston calipers on our cars? Maybe Steve can figure that out when his parts arrive.PeteInCT said:It's not your calipers. Save your money.
Great, I'm sure many members will appreciate that. I'm curious to see if the six piston calipers use a bracket for mounting and if so if that bracket will work with the four piston calipers. If so we can buy the bracket and rotors and use the stock calipers.steveespo said:I will be posting full info on the GT 500 stuff as soon as I can, the shipment is scheduled to be here tomorrow so I will post pics and give the pad size at the least. Mock up of the rotors and calipers will have to wait until next week
KNS Brakes said:My braking became much better when I improved threshold braking WITHOUT getting into ABS.
zzyzx said:Care to elaborate?
Ditto. I learned quickly autox'ing the Boss that the ABS system doesn't take kindly to stomping on the brakes. It's always hard to tell what you're going to get on this front - my Subaru handles this like a champ but that's an apples to oranges comparison to say the least. Yesterday at Homestead I was doing threshold braking the entire time... smooth inputs all the way around.
NFSBOSS said:I wonder how much additional brake pad surface area there is on the six piston calipers vs. the four piston calipers on our cars?
zzyzx said:Well, we know the stock front pad is a CT1001. All we need to know is what this is for the GT500. These diagrams have all dimensions on them.
KNS - Care to provide input here? Do you know what the spec is for the '13 GT500 and if so, could you post a link to the image?
Thanks!
