Hi guys,
I'm wondering the pros/cons with each kit. M-2300-T effectively puts 13/14 GT500 PP brakes in the front and back and the roush kit is just a front brake upgrade. What I'm trying to figure out, is considering the "tuning" of the factory ABS, is it better to use the 4 piston roush kit? the car was designed with a 4 piston caliper, so my thought is I'm not changing anything from the car's perspective other than a much higher quality caliper. I guess what I've read here are the stock calipers are adequate, but with good pads and fluid they are capable. what I want is i don't want to have to even think about burning piston seals, stripping bleeders, or stripping the calipers themselves. I want a no worry brake upgrade. also, as pointed out in the "front brake upgrade" sticky, brake pad availability with the stop techs (assuming they are the same ones that were installed in that thread, only with roush name on side) I may use to 18" wheels, and from what i understand that might make the M-2300-T kit a no go. Also, that kit is heavy as well.
Thoughts?
Thoughts?
