Need more negative camber
52
37
CA
Reviving an old thread..
I recently moved and didn’t have much time to do much with Mustang until about a month ago..ended up making the switch to vorshlag cc plates and cutting open my strut tower and somehow now I’m only ending up with 2.1-2.2 negative camber, I have no idea how that happened. Not sure where I’m losing it though. Plates are maxed and my coil over struts don’t have any slop in the mounting holes, but I still tried to squeeze out whatever I could from there.
I’m really debating going the route @carver went and drilling new mounting holes at the strut tower. But I’d rather fix the issue at the source, any ideas on what could be binding up?
58
41
Atlanta, GA
I'm also facing a similar issue where I'm maxing out on camber plates but only getting -1.5....
Although I'm on BC Coilovers with its camber plate
Top camber bolt has wiggle room for more but it's unfortunately limited by tire clearance.
Frustrated, I went ahead and recently ordered the SPL catalog (LCA, Tension Rod, Bumpsteer) to add camber from the bottom portion of the suspension.
Not sure if I should've rather swapped out for a track-oriented coilover instead...
