BossJockey
Jeff
JScheier said:So... question from the peanut gallery:
If the solution to this is for me to purchase a $750 aftermarket radiator (or possibly M-8005-MGT) and/or add a air/oil cooler, is this the right solution?
Is the client base going to end up logging enough issues with Ford about the cooling on this 'Track car with a License Plate' that Ford implements a solution (which would probably result in M-8005-MGT being installed)? If so, then should we all just wait?
I dunno. If it is just a modification to the fan controller to have it run on 'high'... maybe only with the track key... maybe that resolves it. Maybe it does need a larger radiator. Maybe the water/oil cooler is the issue.
I know Mark Wilson and other Ford Racing employees visit these forums on occasion... can we get any direction from them (please)?
-Will M-8005-MGT resolve the issue?
-If not, does the resolution also include an air/oil cooler?
I'll drop more money if it doesn't look like there will be a factory resolution to this... but I'd really prefer to have a factory fix and/or direction from Ford / Ford Racing as to whether this fix (or another) will make for happier endings to lapping days.
My $.05.
John
From Mark Wilson Re the radiators: "The Boss 302R and 302S use two different radiators. Long story but they both work fine. If it were up to me I'd go with the Ford Racing radiator that is used on the Boss 302S which is more of a car that I'd recommend street Boss 302 owners mimic with their cars as it uses so many Ford Racing bolt on parts. The part number is M-8005-MGT and will reject any heat that the Boss 302 can throw at it."
Also from Mark re the oil cooler: "Contrary to what is published on the Ford Racing website it (302S) uses a unique air to oil cooler. It is more similar to the Boss 302R but not as big due to the shorter nature of the races."
"It would not be economically feasible for us to offer the oil cooler kit we put on the Boss 302S as it included a remote oil filter and custom lines. People would just opt for a cheap kit i'm afraid."
I would not count on Ford fixing the problem because:
1. Very small percentage of owners are having an issue and the car keeps no record of the incident.
2. The car is not warrantied for "Racing", and no one is overheating on the street.
As far as which to do first, if you planning on only tracking your car and not driving it on the street, I would install an aftermarket air to oil cooler. If you planning on driving it on the street, I would replace the radiator. You can get the M-8005-MGT from LateModel Restoation for $660.
http://www.latemodelrestoration.com/item/M8005MGT/2005-10-Mustang-Gt-Ford-Racing-Aluminum-Radiator
