JScheier
Too Hot for the Boss!
cloud9 said:How about an update John ;D
Tomorrow.... tomorrow. ;D
OK it's tomorrow ;D I'm just getting ready to order..........JScheier said:cloud9 said:How about an update John ;D
cloud9 said:OK it's tomorrow ;D I'm just getting ready to order..........JScheier said:cloud9 said:How about an update John ;D
Radiator inbound from LMR. Supposed to see it 8/15. Next track day 8/25 at MPH.BossJockey said:From Mark Wilson Re the radiators: "The Boss 302R and 302S use two different radiators. Long story but they both work fine. If it were up to me I'd go with the Ford Racing radiator that is used on the Boss 302S which is more of a car that I'd recommend street Boss 302 owners mimic with their cars as it uses so many Ford Racing bolt on parts. The part number is M-8005-MGT and will reject any heat that the Boss 302 can throw at it."
As far as which to do first, if you planning on only tracking your car and not driving it on the street, I would install an aftermarket air to oil cooler. If you planning on driving it on the street, I would replace the radiator. You can get the M-8005-MGT from LateModel Restoation for $660.
http://www.latemodelrestoration.com/item/M8005MGT/2005-10-Mustang-Gt-Ford-Racing-Aluminum-Radiator
Is that the one you originally ordered or a different one? If it works for you it should work for most of us.cloud9 said:Radiator inbound from LMR. Supposed to see it 8/15. Next track day 8/25 at MPH.
It's the only one I ordered. Just placed the order Friday night and had it acknowledge today. I'm just following John's lead and Mark Wilson's advice. We'll get there.5 DOT 0 said:Is that the one you originally ordered or a different one? If it works for you it should work for most of us.cloud9 said:Radiator inbound from LMR. Supposed to see it 8/15. Next track day 8/25 at MPH.
ArizonaGT said:In for results of John's Air-to-Oil cooler, next.
JScheier said:Please remember, I'm also at a higher altitude than most of you (5500' or more). That reduces the efficiency of the radiator/cooling.
What I'm going to try next is further opening of the front grille. Increase the airflow some more and see if that helps along with the larger radiator.
If that doesn't work, then yes, an air/oil cooler will go in place of the water/oil cooler.
Dean#4AI said:I was talking to Mark on Sunday about the cooling problems and he mentioned how you were still having problems even after the radiator switch. Then he proceeded to tell me how you guys were talking about it and he finally figured out that you weren't in Texas anymore. ;D
He also mentioned the possibility of modifying the grill but then suggested taking out the grill completely to see if that helped. If it didn't help, then there would be no use in cutting up your current grill.
He also commented about the future possibility of selling Boss 302S grills but didn't say it was going to happen for sure.
