roadhouse racecar build
1,281
Tulsa, OK
Tri-bar said:
I made a template for mine using the Ford Racing one off the F500s and my old bumper cover. It's for a 2012 bumper. It came out dead on. When I get the time I'm going to clean up the template and scan it. I can then Email it to any one who needs it.
So the FR500S template was close? I haven't cut mine yet but I have the template printed off. If your template is better I would gladly use it :)
599
537
Not really, I will redraw it out and send it to you, PM me your email address.
captdistraction
GrumpyRacer
1,955
1,698
Phoenix, Az
I just bought the same bumper beam. I do have the front tow hook kit, but when I looked at the stock bumper bar, the splitter bracket and the tow hook bracket, I thought might as well shave 10lbs off the nose.
I will hit you up about the template, there's absolutely no instructions with any of this stuff.
Has anyone seen directions/templates for the rear hook kit?
1,281
Tulsa, OK
Good call. I welded the rear hook onto the stock beam so I just eye-balled the cut. Not the greatest but it's functional. If Ford provided a template that would be great....(Bill Lumbergh)
Please weigh the stock stuff when it comes off the car. I might be interested in doing the same mod.
steveespo said:
Man I put the CHE ALUMINUM bumper bar up front thinking it would save a ton of weight and it was only 9lbs vs the stock beam. That HSS is really light and strong.
What was the stock beam weight?
steveespo said:
Drew
The stock beam is 16lbs IIRC, aluminum one is 7. I had thought there was at least a 20lb difference but there wasn't.
Excellent, thanks for the info. That's 8-9lbs off the far front of the car. That would be a nice improvement. Maybe I'll get one!
1,281
Tulsa, OK
Big thanks to Tri-bar for sending me his template to cut the bumper cover for the 302S tow hook ;D Turned out great.
Also installed my transponder mount behind the bumper cover. Since mine is rechargeable, this will allow easy access and still shield it from any on-track bumps/love taps.
Slow progress but progress nonetheless...
