Great news! Do you have a photo of the back of the mount?
We already make a plate holder for other cars and yes we will offer one. We are also going to offer the tow hook shaft in 2 versions, 1 will be the thin shaft so as not have to modify the grill at all, 2 the shaft will be larger around and you will have to modify the grill by 1/4 inch by just enlarging the opening that is existing in the plastic.SVTMatt said:Any chance of a license plate holder that'll fit?
Look at above post. I would like to know what you guys think you would want in the way of the shaft size? We will have a 5/8 and a bit smaller shaft so as no mods to the grill. This can be installed with out removing Fascia, just remove the rivets on the belly pan and remove it and you can install from below.50Deep said:Looking forward to pics and the info on the member pricing.
Any way to illustrate where the hook will be on the car? I can't visualize it
It looks real good now that the pics are working.skylane765 said:Look at above post. I would like to know what you guys think you would want in the way of the shaft size? We will have a 5/8 and a bit smaller shaft so as no mods to the grill. This can be installed with out removing Fascia, just remove the rivets on the belly pan and remove it and you can install from below.
VoodooBOSS said:I'm not worried about making minor modifications to the grille and would prefer the larger diameter tow hook.
Your tow hook shipped with small shaft, I can send you larger one MondayVoodooBOSS said:I'm not worried about making minor modifications to the grille and would prefer the larger diameter tow hook.
WE have some made now!! they are in stock with both shafts For 10% off put FORUM in the coupon box at check out.ChevyNick said:The website does not show this as available for purchase; ZL1addons towhook link When will they be available? The people want towhooks!
skylane765 said:WE have some made now!! they are in stock with both shafts For 10% off put FORUM in the coupon box at check out.
