When did your engine blowup?
Somewhere on a forum far far away, there's a discussion thread about this very issue. Ford Racing (as they were known at the time) recommended -12AN (3/4") lines for racing applications with their remote filter adapter. I have a vague memory of Dean Martin's name coming up in the thread, so maybe ask him....Also, is -10AN enough?
plus the boss cooler (which I've heard is roughly 4500 btu with a decent radiator).
The addition of the Setrab660, removal of the oil/coolant, and addition of an oil temp sensor were done over the winter, so no new data yet until get it out to the track at the end of the month. Run time permitting I will plan on gathering some A-B comparisons with the oil cooler blocked and open oil cooler (temp sensor near the sandwich plate pre-cooler) - not the greatest comp, but will see what the cooler is doing. In the past the monitoring was from the OBDII coolant temp (yes inferred temp) which would rise to mid-240's after two hard higher rpm laps, then needed to cool down with some momentum laps keeping the rpm down and working on lines - good part was never went to limp mode. Here are some of the early install pictures.Welcome @chicagobob! Willingness to help makes a great first post in my opinion. Do you have some oil temp data from before and after you put in the Setrab 660?
Thanks for the welcome. Good advice on the grille, the high flow / no grille option is definitely the next item and easiest if needed (the current GT with rally lights is certainly on the low flow side).Bob, Welcome!
The single most effective cooling mod for my Boss was swapping out the grill. Allowing more air to pass through the radiator and coolers was key.
Will you be at the Track night at Blackhawk in May?
I think boxing in the radiator ( beyond factory sealing ) probably is one of the best changes that is not talked about much...Remove grille or high-flow grille. Large oil cooler as you have mentioned. If you are switching out radiator, go to the C&R / PWR unit--it is expensive but it does work. The FRPP radiator was about as good as the stock Boss radiator, the C&R dropped my ECTs around 20*F by comparison--because there is more radiator surface area exposed to the lower grille where (surprisingly) most of the cooling airflow comes from.
Beyond that the next step (or you can do this today for some extra help) is to box in the radiator area. Both @Black Boss and I have information on that buried in our build threads.
