High oil temp (overheating at track)
Discussion in 'Boss 302 and S197 Technical Forum' started by SGwick, Mar 9, 2017.
  1. Coz
    Coz TMO Race
    209
    153
    Mar 4, 2018
    Philly Metro Area
    Grant 302, twistedneck and VoodooBoss like this.
  2. twistedneck
    twistedneck TMO Race
    315
    29
    Oct 15, 2014
    Dearborn, MI
    Ive been super bsuy w stuff now back at it! Thanks Grant 302.
    Makes sense, i had to switch to the 3.5 twin turbo pcv it was eating oil bad.. valves nasty etc.. now it does not eat oil as bad but still.
    Will swap out the $100 worth of new 5w-20 mobil one gold oil after the initial fun. Battling a 2018 ss 1le and a tracked out miata. The miata was also over heating till new rad and air flow.
    Will dig for pics of the cars in this thread.
    Grant 302 likes this.
  3. twistedneck
    315
    29
    Oct 15, 2014
    Dearborn, MI
    Forgot to ask. Looking at the $400 upper cobra jet grill thats pricey. Also, from what i have read here the lower grill is also of major importance.
    Has anyone taken a dremmel and cut out a bunch of the factory grill blocked holes? Can same be done w the lower? This will add drag and reduce downforce (can u say current gt500 development issues anyone?)
    Also, wont the extended life mobil 1 5w 20 $$$ oil i got hold up better than normal syn blend 5w 20 for just the one noob track day in sept?
    I remember reading that ford did not like the 10q-50 oil w 2011 or 2012 because of the jets.. and thats why they were able to run it w the boss and the 2013 sice the squirters were deleted. All just random nothing in stone.
  4. TMSBOSS
    TMSBOSS TMO Addict
    3,586
    820
    Aug 23, 2011
    Cobra jet grills are pricey. Try simply removing your grill if you get too hot. Then go from there.
    Yes, several guys did cut up their stock grills to increase air flow. I believe they saw some improvement. Not as much as a CJ grill or no grill.
    VoodooBoss, Grant 302 and twistedneck like this.
  5. Grant 302
    Grant 302 OPM Spent: $587,402 Moderator
    6,252
    1,385
    Nov 23, 2011
    In the OC
    I think you'd be okay with one day on fresh 5W-20. That's the current recommendation for gen2 performance pack GTs.
    Good points about the stock GT lower grille. I put in the GT/CS Boss lower for that plus brake duct and splitter. The center is relatively open with only two upright posts.
    twistedneck likes this.
  6. twistedneck
    315
    29
    Oct 15, 2014
    Dearborn, MI
  7. VoodooBoss
    VoodooBoss Rick Moderator
    19,966
    2,404
    Nov 30, 2010
    Let us know how the grille works. You'll need to contact Cooltech on the missing parts.
  8. Coz
    Coz TMO Race
    209
    153
    Mar 4, 2018
    Philly Metro Area
  9. Grant 302
    6,252
    1,385
    Nov 23, 2011
    In the OC
    Oops. You mean the fittings in this picture next to the sandwich plate aren't there?
    [​IMG]
    I'm sure cooltech will take care of you...
    That grill should be open enough. Been in the pictured car for a few joyrides...
  10. twistedneck
    315
    29
    Oct 15, 2014
    Dearborn, MI
    No those two black fittings w o rings are there. I use those to attach the 90 degree female ends to the heat exchanger.
    I dont see anything to attach the straight female ends on the other end of the hoses to the sandwich plate? Is there a fitting built in to the setrab that i didnt notice?
  11. Coz
    Coz TMO Race
    209
    153
    Mar 4, 2018
    Philly Metro Area
    You need two more for the cooler. The sandwich plate and the cooler both have M22 female ports.
  12. twistedneck
    315
    29
    Oct 15, 2014
    Dearborn, MI
    Thanks Coz, im kinda bummed gotta pick the car up tomorrow.. new trans and shifter yea, but no cooler :(
    I wonder why they dont ship them with the kit? They are not even mentioned in the instructions either.. and the pic on web shows only two.. says everything you need is in kit. Something has gotta be nit right. Maybe its screwed into something hiding!! Hehe. Ahhh well..
  13. Coz
    Coz TMO Race
    209
    153
    Mar 4, 2018
    Philly Metro Area
    I just received the same kit last week but I'm not home right now. I'll have to double-check it tomorrow. I know the cooler and sandwich plate were drop shipped direct from Setrab and the lines came from Cool Tech.
    Perhaps each company thought the other was providing one set of fittings.
  14. twistedneck
    315
    29
    Oct 15, 2014
    Dearborn, MI
    Good point. Yes mine arrived the same way.. two seperate deliveries first from setrab second from cooltech.
    I will buy from granger tomorrow if possible but thats a pretty unique fitting.
    Now that i have time, is there a recommended temp gage and install kit that would be good to put in now? I need to also put it on the hot side not the cooler return side. Tbd on which line is the return.
    Ps. This makes sunday interesting! Thanks for the help. Now, how to gut the lower grill and install watson plates. I do have the tube rad support so i think that will enable.
  15. twistedneck
    315
    29
    Oct 15, 2014
    Dearborn, MI
    Cooltech is so bad ass.. Kendall already got back to me and the two missing fittings will be shipped in the morning.
    Seems setrab used to include them..
    Now that is some great support by Cooltech, impressed.
  16. Coz
    Coz TMO Race
    209
    153
    Mar 4, 2018
    Philly Metro Area
    By the way, a question for those that have a sandwich plate.
    The Setrab Hyperflow sandwich plate doesn't have any 1/8" NPT gauge ports. I know some people have substituted the Mishimoto plate instead but I prefer to use the Setrab because...well because its a Setrab. And I already paid for it...
    Kendall at Cool Tech stated they have been successful in drilling & tapping the plate. As an alternate he suggested a male to female swivel 10AN adapter with a port such as this:
    https://www.summitracing.com/parts/fra-495008-bl
    I'm a bit nervous about figuring out the right spot to drill & tap but will do so if its the best way. Any recommendations on the best way given any space constraints for either method (for the sensor or wiring). Will one way or another will affect temp readings significantly?
    Thanks.
  17. Coz
    Coz TMO Race
    209
    153
    Mar 4, 2018
    Philly Metro Area
  18. twistedneck
    315
    29
    Oct 15, 2014
    Dearborn, MI
    Got the high airflow upper grill installed from trufiber. Cooler going in as soon as the two missing fittings arrive from Cooltech.
    https://drive.google.com/file/d/1aXEZagp-NiN-xq0ciLteYGP4-4RPERPM/view?usp=drivesdk
    This seems like an uglier alternative to the cobra jet grill for $75 less. Its about 5lbs less weight than ztock GT grill and lights.
    PM me if u need i install notes. No need to pull the bumper. So much more cooling!
  19. Coz
    Coz TMO Race
    209
    153
    Mar 4, 2018
    Philly Metro Area
    Very nice. Very pricey.
    I may modify my stock GT upper grill by drilling out some of the blocked off hex areas along the upper & lower edge of the grill.
    I did something similar on the left & right side of the lower grill when I installed the Vorshlag brake cooling inlet ducts.
    I used a 7/8" hole saw and that got 90% of each hex opened up & finished opening the rest with a Dremel. Of course, 90% of the time was spent on that last 10%, lol
  20. twistedneck
    315
    29
    Oct 15, 2014
    Dearborn, MI
    Coz that is a good less expensive (nearly free) alternative. And better to look at.. this is an ugly beast but hell.. all in the name of cooling.
Share This Page
