Where's Wally
Black Boss said:
Rear Camber was 1.2* from the factory, very close to the R Track spec of 1.25* so I didn't change it. Spec for 350 is 1.00*
Rear tire wear looked even, but we'll see what happens when pushing harder. Of all the alignment settings, rear camber is the most difficult to adjust -- the bolts are well buried.
Also my Rear Toe was 3/32" In. Both the 350 and R Track specs are 0.30" (11/32") which seems really high -- I didn't alter mine, and didn't experience any instability under braking. Anyone @ArizonaBOSS @VoodooBOSS @fuhrius @Moto @voodoo child21 have any insight on rear toe -- this new fangled IRS is new to me ;D
In general, for an IRS car, the "fast" setup is a little toe-out in the front suspension, a little toe-in in the rear. Toe out in the rear is not good.
VoodooBOSS said:
I think the difference in the factory recommended camber settings is more tire than suspension dependant. Regardless they aren't going to be relevant for many of you. ;)
Agree, tires will be the biggest variable, and we are only at the start of the learning curve....
ArizonaBOSS said:
In general, for IRS, the "fast" setup is a little toe-out in the front, a little toe-in in the rear. Toe out in the rear is not good.
Thanks -- makes sense.
8250RPM said:
Rear toe would be best at 0-.062 according to Vorshlag on a IRS
Now that makes sense -- I'd mis-read the spec it's 0.3* in not 0.3in
it's interesting that the front toe settings are quite different. the gt350 has toe out of .1 degree and the r has toe in of .06 degree.
That actually makes a lot of sense, Althought it's the same car it's an apples to to green apples situation. damn, I need my GT 350 :-[
A good majority of these cars will be on aftermarket track wheels with R compound tires on the track so the Ford alignment specs for the OEM Michelins go out the window to a degree. I would bet the most popular choice will be R7s for both GT350 & GT350R owners meaning the alignment specs will be similar. Realistically how much difference is there between .06 and .1 degrees of toe anyway? I have generally run zero toe on the front since I still drive mine on the street to preserve the street tires.
Nick did you add TPMS to your second set of wheels? If so what frequency are the sensors. I see 433 and 313 Mhz sensors available from RoushYates as take offs. Also what stems did you use, the DILL-VS-925B?
VoodooBOSS said:
8) Did Track Day Solutions make those for you? Also which lug nuts did you use with your Forgestar wheels? I'm looking at these due to the recessed nature of the GT350 front wheels.
http://www.amazon.com/gp/product/B00SF8FA7C/ref=ox_sc_sfl_title_3?ie=UTF8&psc=1&smid=A2F8QH83YSA2LG
I used these Titanium 12 point lug nuts. 3.5 oz for titanium. 12.5 oz for the stock
