Let's see how I did on my predictions from early May then updated in early September:
Names:
So far so good. Nothing was mentioned about an R version but it's coming.
Availability:
Hit the announcement on the head and I still expect the car to be available Summer 2015 or possible early Fall.
Engine:
I knew I had it wrong but corrected myself in September. Still no HP numbers but I'm holding at 550 which might be a bit high.
Brakes:
Yep. Look for CCB's on the R. I actually undershot on the front rotors. :
Wheels and Tires:
Off by a little bit on the front tires at 295/35/19 but got the tires correct. The R will have the Cup tires and I'm still holding at 305F and 325R.
Suspension:
Wrong. Oh well the MagnaRide suspension will be awesome for street and track. I'm still holding out for Multimatic DSSV dampers on the R and maybe they will be adjustable.
Differential:
Correct
Trans:
Aren't we glad I'm wrong here! ;D The new Tremec 3160 should be a sweet shifting transmission.
Clutch:
Correct
Driveshaft:
Wrong. Looks to be aluminum and not CF. At least it's not steel.
Edit: maybe the R will have a CF driveshaft.
Names:
Availability:
Engine:
Brakes:
Wheels and Tires:
Suspension:
Differential:
Correct
Trans:
Clutch:
Correct
Driveshaft:
NFSGT350 said:Ok here's the latest on the GT350 program.
Names:
I'm now completely confident that name will be GT350. The race car versions will follow the same naming convention for the FR500 and Boss 302 programs. This is a SVT car and will also have the Shelby name on it although Shelby America will not be involved. There will be four models:
GT350 – the base GT350 similar to the Boss 302.
GT350B/PR – similar to the Boss 302 Laguna Seca. This is the higher performance GT350 or street legal track day special. B/P stands for SCCA B Production and pays homage to the original cars. The original GT350 won it's very first B/P race and went on to capture the SCCA 1965, 1966 and 1967 B Production championships.
Turn Key Race Cars
GT350C - for IMSA CTSCC GS class racing, the enduro racer. Updated
GT350S - for World Challenge GTS class racing, the sprint racer.
Ok I was reaching on the B/P name and trying to be creative. But I still got most of this right.
Availability:
The GT350 will be announced at the 2014 LA Auto Show most likely on November 21st the first public day of the show. Look for GT350Mustangs.com to be there for the live announcement. The first we'll see the car at a race will be in the CTSC GS class at Daytona in January 2015. IMSA let Ford race the Boss 302R before production began as they did with GM and the Z/28. Look for the production cars to be available at the earliest in Summer 2015 most likely as a 2016 model. It could be a 2015 model but who really cares?
I'm sticking with this one to the letter although we might see a press release or event prior to the LA Auto Show.
Engine:
Sorry but no flat plane crank.Wrong! I know there's lots of rumors on this but it just doesn't make sense for the price point or for the production class racing. If Ford is working on a FPC look for it in a Mach 1 or GT500 a couple of years down the road. What the engine will have is 520 HP in a 5.2L engine with a redline of 8,000 RPM's. While the Boss engine has been pretty bullet proof the weak link has been the valve springs. Look for improved flow in the heads with hardware that can take 8,000 RPM's during the durability testing. To feed those heads there will be a new intake similar to the Cobra Jet intake but with a few tricks added to it to take advantage of the increase flow through the heads and larger bore. A new larger throttle body will be paired with the intake. Shorty headers will be stock but with slightly larger primaries to take advantage of the increased flow. The really big news will be the GT350 will be the first Mustang with direct injection.
The FPC Voodoo engine is real but I don't have a lot of details. I'm bumping up my initial HP guess to 550 HP. So somewhere between 520-550 and the redline could be 8,500 or higher.
Brakes:
We've already seen mules with carbon ceramic brakes with 15" rotors in the front and 14" rotors in the rear. They will be matched with six piston front and four piston rear Brembo calipers. This time around the B/P will have more track oriented brake pads compared to the base GT350.
No changes here. Look for the CC brakes to be stock on the GT350R and an option on the GT350.
Wheels and tires:
The GT350 will have Michelin Pilot Super Sport in295/35/19 and 265/35/19 on 11" and 10"wide wheels.This will open up larger rubber on the stock wheels come replacement time.
The big news is the GT350 B/P will have Michelin Pilot Sport Cup tires.It's possible they could show up with Pirelli P Zero Trefeo R's but it will depend on what manufacturer Ford contracts with.
We now know the wheel sizes are 19x10.5F and 19x11R for the GT350 with the R getting 19x11F and 19x11.5R. And as I posted last week the R will have carbon fiber wheels and most likely made by Carbon Revolution as previously shown in the Leno's Garage video. WOW this is huge! Make sure you leave plenty of room on your credit card for replacement wheels. Tires are as I previously predicted but with larger sizes. 305/30/19F and 325/30/19R
Listen to what the guy has to say about an OEM deal at the 4:00 mark.
https://www.youtube.com/watch?feature=player_detailpage&v=gWiTky3zZXQ
Suspension:
The cars will have Multimatic dampers with DSSV technology. The base GT350R andB/Pwill have different valving but will be identical otherwise. The beauty of this is you can upgrade the base dampers with the B/P cartridge for more damping control. Yes I know the Z/28 has them too but Multimatic uses the same technology in F1 cars so think of it in those terms. The R and S cars will also have DSSV dampers with remote reservoirs on them. The street dampers will have nothing in common with the race dampers other than using a DSSV cartridge and being made my Multimatic.
I don't have any further information on this other than Multimatic has two of the GT350R(S) cars they are prepping for IMSA next year. So for now I'll stick with my original prediction.
Differential:
No electronic controlled diff like the new Stingray. Look for a Torsen similar to the Boss 302.
No change here.
Transmission:
Sorry but the Getrag MT82 remains the stock transmission. Look for improvements in durability and smoothness. The transmission will have an auto blip feature.
I'm beginning to think I'm wrong here and hope I am. Frankly the sky is falling mentality about the MT-82 is unfounded and the clutch on the Boss 302 is the main problem.
Clutch:
Look for a twin disc clutch similar to what Ford uses in the GT500.
No change here.
Driveshaft:
It will have a carbon fiber driveshaft similar to the current GT500.
No change here.
