- Thread starter
- #61
cloud9 said:
NFSBOSS said:I wonder if FRPP will make this rear mount battery kit available?
Zquez said:Its not necessarily a kit.... but the tray is already available under the cobra jet stuff. $60
cloud9 said:I just weighed the Kooks LTs and they're 12 lbs each. Anyone know what the factory exhaust manifolds weigh? I'm waiting for some weather above zero before I'll get them installed.
Woot! How ironic that I'd go for the chair parts. Go figure.ArizonaGT said:Found some 1.5" BLACK chair tips at Ace...sound tube cap no longer white.
Now if you can find a place on your Boss to use some casters.cloud9 said:Woot! How ironic that I'd go for the chair parts. Go figure.
cloud9 said:Reduce engine flex to hopefully help with high RPM shifting. Actually the motor mounts are only nominally more work while they're installing the headers. Even by themselves it's a fairly quick job.
2012YellowBoss said:Nominal my A$$ ;D The vid says an hour and a half ..... day and half is more like it, that is what it took me. What a PITA I had to take apart many things, like the oil cooler tube, wiring etc. The Boss is very different from the older style S197 in that vid. Getting at the bracket bolts are very difficult and I do not recommend doing this yourself unless you are very mechanically experienced. I ended up taking out a bolt on the passenger side I thought was a bracket bolt but was not, I also took off a header nut thinking it was on the bracket.
Prothane and not sure why they only show 2005-2009 but they're 2005-2013.JTRATX said:What mounts are they?
2005-09 Mustang Prothane Urethane Motor MountsJTRATX said:What mounts are they?
cloud9 said:That's why I'm letting the mechanic install them when he pulls the motor to install the headers
part was a site general statement and not directed at you (Gary) ;D2012YellowBoss said:unless you are very mechanically experienced
cloud9 said:LOL who are you kidding I'm not pulling my motor.....I know my limitations
Thanks for the writeup now I'm more anxious than ever to get them installed. Of course since it's only 3 degrees outside right now there's really no rush.
They called off school tomorrow it's going to be so far below zero. Just flashed in the tune for the LTs and H-pipe and was worried the PCM would "freeze" up ;D LTs and H-pipe going in next week when temps are expected above 32......barely.drano38 said:Gary, its a heat wave for the next few days--better get those mods done!
