Need more negative camber
52
36
CA
Wondering what the best route for more neg camber would be? I currently have MM cc plates and I’m getting -2.7 but after putting 19x11 with 305s up front it looks like I need more to get the wheels to tuck under the fender.
Has anyone drilled the strut tower and managed to get more camber from the MM plates or would I be better off slotting the strut mounting hole?
Any other options or advice is welcome..
52
36
CA
Luckily the MM plates haven’t given me any issues other than not providing enough camber. Vorshlag plates would be nice but not in the budget. Seems like drilling the strut tower mount holes would be the most cost effective and still get the extra camber I need.
Thank you all for the quick response!
899
546
We have cut the strut tower opening like above on every S197 and S550 that sees track duty. The first limit you run into with anyone's camber plate is the strut tower opening. Vorschag used to sell a jig for use with a hole saw. But, you can drill a pilot hole inboard, then cut a hole with a hole saw, and then even up the opening like above with a cutoff wheel or grinder.
5,244
4,233
I had the same -2.5 max camber with the MM plates. Adding upper and lower camber bolts got me up to a max of -5 degrees camber. Finally settled on -3.5
531
364
sfo
Don't you want to add camber at the strut top and reserve the camber bolts for tire clearance because messing with camber bolts negatively effects scrub radius?
531
364
sfo
I have the vorschlag jig if anyone needs one. An advantage to the bigger hole is to access the rest of the adjustment screws but TBH I have never adjusted those and to see what your camber is on the scale. But the slot method might remove less metal and keep things stiffer?
5,244
4,233
Not really since already running a 25mm spacer for the 315 up front. Am confused by "reserve the camber bolts for tire clearance"
5,244
4,233
View attachment 70570View attachment 70571
Which wheels are those? We had problems with the SVE 350R wheels. the offset left almost any tire hanging out.
carver
breaker of wrenches
446
605
ontario
Carver, Sometymes old school prevails over new stuff......you know you're not a spring chicken anymore when you even talk about old school...but it does bring back pleasant memories.........................at least for me................................:biggrin:
Hah, That's one of my favorite things about the Boss 302 is it has so much old school DNA but also modern perks and safety!! :hellyeah:and yes I have fond memories of the 60's and 70's....crap I'm getting old !!
6,401
8,294
Is that a fixed position plate or will it slide in slots ? looks kinda custom made ....which I really like !!
it slides, if you call Phoenix they can fill you in.
52
36
CA
They are the SVE X500 so they have the same +50 offset as the 350
Did you ever find a remedy?
I was going to go the same route as @carver and shift the strut mounting holes over but now I’m not sure that will be enough.
5,244
4,233
Sorry, he had the 19x10 fronts with a 40mm offset. I forgot you must have the square 19x11 setup.
Fair
Go Big or Go Home
277
492
Plano, TX
As many have said, this camber travel limitation is likely from your strut tower opening...
As you can see, the S197 hole is less than 2" in diameter, and the shaft on non-inverted struts sticks up above this...
Most struts made for the S197 are non-inverted and have this long upper threaded stem, and often an adjuster knob, that will limit your inboard travel.
Starting in 2015 we started using a fixture we built to cut the towers on the S197, which opened them up for a lot more camber and caster travel with our camber/caster plates.
You can use whatever hole saw size you want but we recommend a 2.5" or 2.75" OD version to keep the maximum strength in the cold formed upper "tower" section - that gives you PLENTY of travel.
For about 2 years we loaned out our one fixture tool, but it kept "not coming back" so when we got a CNC plasma table in 2018 we started making these...
We make them for 5 chassis now and they sell like hot cakes. We don't make much money on these, but it provides a service to the community, and we encourage people to share them with friends. Some shops have bought "one of each" and they can be used dozens of times.
https://vorshlag.smugmug.com/Instructions/S550-Strut-Tower-Clearancing/
The link above is a step-by-step instruction gallery of how these work, and the S550 tools are one of our most popular (we've sold 100s).
Cheers!
