Where's Wally
VoodooBoss
Rick
Nice price if they work well on track. Who makes the pads?
Don't know for sure, but with "Contents made in Italy", I'm thinking Brembo might make them.
Excellent pricing for Race pads, and it will be interesting to see the base line results.
Based on the Track tour and in discussions with the Ford Performance guys, I think these pads will be fine for Track use. Pads are sourced from Brembo (inner packaging on rears has Brembo label). Friction material for both Front and Rear is Ferodo 4446/2FF. Both front and rear have what appear to be integral heat shields, and both have wear indicators.
The fronts are Huge compared to the Boss. Will post photo later......
cloud9
Gary
That's great to hear as I'd love to run as much "stock" as possible on this car. They really do seem to have built it as a track car from the ground up. I think it was in the supplement that it said you may notice some squealing at low speeds. That's a good indication that they are a track pad.
I did say Huge; Boss front pad on the left, it's big brother on the right:
The rears by comparison appear to be (only) 30-40% larger!
Note what appears to be an integral heat shield:
Each seat of pads came with anti squeak lube:
cloud9
Gary
That is awesome! That's actually the item I'm most excited about with the GT350.....the BIG BRAKES. It will be a huge deal at my favorite track Road America. The pad thickness is concerning so the fact that they're so cheap is a big bonus. I was going through a full set of front Hawk DTC70s PER DAY at RA. Hopefully with the larger swept area on both front and back, we'll get better longevity given the weight of the car is close. That being said, all it really means is I'll break later and deeper so may end up with similar wear characteristics.
Does the anti-squeal lube go on the pad material? Wouldn't it just wear off right away? Maybe it's something you'd only use on a street driven car?
mattlqx
Mustangless
Oh dear, no. Then you'll never stop. It's for the backing of the pad to deaden vibration between the plate and the pistons.
cloud9
Gary
LOL I figured as much. I've never bothered to use it and just live with the squeal once you wear the bed in material off the rotors driving around the street. I usually bed them and am back on track before they get that clean anyway.
cloud9
Gary
VooDooBOSS said:
I'm still leaning to the skeptical side on the brake pads until proven otherwise. ::)
Fortunately Black Boss will figure it out before I have to order backups :) Realistically I'm not sure what other options I have at this point anyway as I haven't seen any other options offered for our cars as of yet.
The pic comparing the new Brembo 6 piston caliper pads to the Boss Brembo 4 piston caliper pads is impressive. I think you have a good plan to establish the OEM brake pad wear baseline under race conditions.
As for alternative Aftermarket pads for the GT350, I suspect the Brembos will have ample choices available in pretty short order. And who knows, the OEM pads might turn out to be the pad of choice, wouldn't that be something?
What brake fluid is spec'ed for the TP cars? Is it 600 plus degree Dot 4 fluid? Is there any difference between say the TP cars and non TP optioned cars? Any difference in brake fluid spec for the R optioned cars?
Gosh, back in the day, I remember being happy about the fact that Ford spec'ed Brembos for the front brakes on my 2012 Boss 302 (500A)! This is a fine example of "The Spirit of Competition" as defined by Dr. Fredrick Simeone.
As performance minded sports car enthusiast, you have to love this very special moment in time for Detroit automotive performance excellence.
Enjoy it!
Dave, 302 HP
cloud9
Gary
Enjoy it!
Dave, 302 HP
Brake fluid - Motorcraft DOT 4 LV High Performance Motor Vehicle Brake Fluid PM-20/WSS-M6C65-A2
VoodooBoss
Rick
The new brakes look awesome and worked well during my three laps at Laguna Seca. All GT350's come stock with DOT 4 fluid. The engineer I bugged the crap out of at the Historic Races told me the cars are ready to go right off the showroom floor and to literally drive them on track with no modifications and that included the brake fluid and pads.
I just found this info and table. I've been using Motul 600 and will continue to do so.
http://www.readautomotive.com/2015/03/brake-fluid-comparison-table.html
Wally is still at Watson, but Patrick sent me some photos and the Roll Bar is in:
Plan to go collect the car tomorrow -- hopefully it stops raining, and I will not need to trailer again...
Will take more detailed photos tomorrow.
