F.D. Sako said:What's involved in installing these?
do we have to unload the transmission weight from the mount before sliding the inserts in?
pufferfish said:also available to purchase from your friendly neighborhood Blowfish!
http://stores.blowfishracing.com/-strse-26/Transmission-Mount-Stiffening-Insert/Detail.bok
but sadly, my stock won't be here for 2-3 more weeks.
jim woodruff said:there is an install sheet on the whiteline web site.
ArizonaGT said:Could you put it in from the rear side without dropping the trans crossmember?
pufferfish said:Looks like the crossmember captures the insert. Putting in rearward would not capture it. I would think you could save a step and just unbolt the mount from the crossmember and raise the trans to gain access, right?
OK no problem, thanks for confirmingdabossinne said:No. The ridges on both the front and backside of the crossmember casting block access to the bushing.
torque is 3.5 grunts with a breaker bar lol. thread locker and nice and snug you will be setF.D. Sako said:now if only someone posted the torques required on those bolts... this thread would be complete lol after dabossnine's 2-3 shift impression, of course.
my 1/2" torque gun has settings of 1 2 3 4.. 4 being break the heads off of the bolt so I stick to 3 and thread locker lolBrandon302 said:Torque specs and picture http://iihs.net/fsm/?dir=1115&viewfile=Crossmember%20-%20Transmission,%203.7L%20and%205.0L.pdf
I hope thats not the case for me. if it is I will have it up for sale same day lol. I have bbr motor mounts already and they arent bad at all.captdistraction said:jesus the NVH.
Drove it around today with the bushing in, this is definitely a track day only part, at least on my car. introduces a lot of vibration into the cabin, and noise. shifter doesn't shake around a lot, but I already have a barton bracket and steeda shifter.
Going to pull it out for my sanity and just install it on track days. It does help firm the setup up.
